bad Gas milage STILL!!
Old Apr 15, 2002 | 10:37 PM
breathment's Avatar
Ok, replaced plugs\wires\cap\rotor, and recently installed new headers, which i thought would help the milage. but before the plugs etc. i was getting about 13.5-14 MPG. and after i was getting the same. AFTER the headers, i was expecting an increase of at least 1 MPG.. nope, still getting 13 MPG and 14 if im lucky.. I can drive like an old women with no feet and I still get crappy millage. I seem to actualy get better millage driving it hard every once in a while. What should i go for now? Does igniton timming have anything to do with millage? Tire pressure is 32. HELP. should i replace EGR stuff? Im not getting any codes..
Old Apr 16, 2002 | 09:53 AM
camaro6spd's Avatar
ummmm, maybe your injectors are off.....also...what about an 02 sensor?
Old Apr 16, 2002 | 01:43 PM
xxwarrior36xx's Avatar
I don't want to be technical man but I have a 5 speed and a baby 305 and only get 15 in the city. That is normal man relax.
Old Apr 16, 2002 | 02:07 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
I'v got everything in my sig and get 16 around town and 21 on the highway and this is with a carb. Definately check your timing i gained about 3 mpg once i got my timing right. Then check your sensors starting with O2 and go from there.
Old Apr 16, 2002 | 08:21 PM
jms's Avatar
jms
The mileage you are getting is not normal. I have seen over 30 in my '88 GTA (350) several times. Mostly in the high 20s for mpg.
The factory rated these cars at something like 17-18 in the city and 25-26 highway.
Headers do make the mileage better---IF you keep your right foot out of the firewall.
I don't know your problem but there is something wrong.
jms
Old Apr 17, 2002 | 02:34 PM
breathment's Avatar
the O2 is new. and i know that i can get better millage, because I HAVE GOTTEN 16 MPG before, when i first got the car from my uncle, and it slowly went down to 15 then 14 for the longest time, and now im getting 13..
Old Apr 17, 2002 | 06:26 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Overall, how is your car running? When my car ran good, I got 17mpg. Currently, my car is running very rough overall and I am getting 11mpg.
Old Apr 17, 2002 | 09:17 PM
breathment's Avatar
it runs pretty good. idles nice, doesn't miss or anything.. im gonna try and get some specs tomorrow, fuel pressure, vacume, compression etc...
chazman
Aug 28, 2018 03:25 PM
Jae992
Aug 27, 2015 09:07 AM
chazman
Aug 22, 2015 02:01 PM
Bradsaundry
Aug 12, 2015 12:34 AM
