Injectors not firing
Old Apr 16, 2002 | 07:20 AM
texasgt's Avatar
Car: 2003 HD 1500 4 door Chevy
Engine: 6.0
Transmission: 460LE
I am swapping in an 89 L98 into my 85 IROC. I used an 87 harness (from 305 tpi) to replace my 85 harness. I have an Ed Wright chip for the 89 computer to override VATS. All power is on and and the fuel pump is priming when the key is turned. However the injectors are not firing. I am clueless.
Thanks for any help.
Old Apr 16, 2002 | 11:15 AM
Guest
Guest
Posts: n/a
If its not the VATS (still suspect IMO) then check to make sure the distributor and wiring is correct, it needs a reference signal before it'll fire the injectors.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
sahlomonic
Sep 20, 2015 07:15 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
