Engine Still Missing a Cylinder
Old Apr 16, 2002 | 07:20 PM
87LB9B4Z's Avatar
Car: See ID
Engine: See ID
Transmission: M39
Folks, I need help. I've got a partial miss that's proving to be a bear to hunt down. I have replaced the plugs, wires, distributor, rotor yet it persists. Pulling a plug wire results in the expected change in idle for every cylinder.
I have to take a 600 mile trip in two weeks and really need to have all eight cylinders fully functional.
Old Apr 16, 2002 | 07:28 PM
ede's Avatar
ede
no codes? replaced filters good fuel preasure and volumn? run a compression check
Old Apr 16, 2002 | 07:32 PM
87LB9B4Z's Avatar
Car: See ID
Engine: See ID
Transmission: M39
No codes.
I was afraid someone would suggest a compression check. What a major pain in the rear. I have stock exhaust manifolds and spent the better part of 2 hours changing the plugs...
Fuel pressure's good. It is a miss across the RPM band without variation.
Old Apr 16, 2002 | 08:49 PM
Hellraiser's Avatar
Originally posted by 87LB9B4Z
No codes.
I'd also say do a compression test first... Sounds like it could be a bad valve somewhere.
Hellraiser
Old Apr 17, 2002 | 07:18 PM
87LB9B4Z's Avatar
Car: See ID
Engine: See ID
Transmission: M39
I was hoping one of those... solutions. I guess that was too much to hope for.
I hope it doesn't get any worse. I must drive to Mississippi weekend after next and will not have time to fix anything so involved as a valve problem.
Thanks folks.
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 22, 2015 08:17 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
