Rough running TPI IROC
Old Apr 14, 2002 | 01:30 PM
Dingus's Avatar
Hi everybody, I'm having trouble with my 85 Iroc. It started about two months ago with the car getting hard to start when the engine was cold. About two weeks ago, it developed a skip at idle and a nasty skip under load. I've replaced the plugs, wires, coil, and fuel filter. The timing is still where I set it, but seems to be unsteady when I reconnect the wiring harness to the distributor. I'm out of ideas. Any suggestions?
Old Apr 14, 2002 | 02:05 PM
iroc_cragg's Avatar
Hey
I would set all the timing and stuff to stock specs. I would also go and get a compression test done on ur engine. Something might be wrong there. Does ur check engine light come on or not. If the check engine light comes on tell us.
Http://camaroz28.cardomain.com/id/56424
Old Apr 14, 2002 | 02:22 PM
Dingus's Avatar
The check engine light isn't on. I was hoping it was something simple that I may have overlooked. The engine only has about 35,000 miles on it. I forgot to mention that since I replaced the coil, it started backfiring. I don't know if that means anything other than I'm screwed.
Old Apr 14, 2002 | 02:48 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I would check the condition of all your plug wires. Make sure there are no cracks. Even though they're knew may not be enough, I know I've burnt a couple wires after replacing them.
Do you have a cat?
Old Apr 14, 2002 | 04:24 PM
Dingus's Avatar
The wires are good, it was a pain trying to route them away from the headers. I've gone through and double checked for any grounded wires and also for the proper order to make sure that the right wires were in the right cylinders. Yes, I do have a cat, but it's only about two years old. Could the cat be causing a problem? If so, how would I check it?
Old Apr 14, 2002 | 04:30 PM
iroc_cragg's Avatar
Have u ever done the 1/4 mile in ur 1985 IROC Z.
Old Apr 14, 2002 | 04:49 PM
Dingus's Avatar
Nope, I've never taken it to the track. But, I do have alot of fun humiliating the sport compact guys. Well, not right now since my car is sick.
Old Apr 14, 2002 | 04:58 PM
Car: 99 Formula
Axle/Gears: 342
Usuall if the cat is clogged, it might glow or the car will tend to run warmer than normal.
Old Apr 14, 2002 | 05:24 PM
Dingus's Avatar
The car still runs at it's normal temp. This thing just has me stumped.
Old Apr 14, 2002 | 08:41 PM
87LB9B4Z's Avatar
Car: See ID
Engine: See ID
Transmission: M39
Have you checked the fuel pressure? How about the EGR? Is there any time when it runs smooth?
Old Apr 15, 2002 | 07:56 AM
Dingus's Avatar
I haven't checked the fuel pressure or the EGR. It has a lumpy cam in it, so it has never really run smoothly. But, it runs normal cruising down the highway until I give it some gas, then it starts skipping causing the whole car to shake. It also skips really bad when I take off from a dead stop. Basically if I accelerate, it skips. I hope it's not the fuel pressure, because I hear that pulling the fuel pump is a nightmare.
Old Apr 15, 2002 | 05:12 PM
87LB9B4Z's Avatar
Car: See ID
Engine: See ID
Transmission: M39
Replacing the fuel pump is a pain, but no worse than most other jobs on Camaros. I've done it twice in 9 years.
Get a fuel pressure guage and put it on that puppy. It should read about 40 psi at idle and rise to ~45 when you hit the throttle. If the pressure drops its probably a bad pump.
Old Apr 16, 2002 | 01:14 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Have you checked the fuel pressure regulator to see if it is leaking? Hard to say if that could be it, but if it was hard starting it might be....
Old Apr 16, 2002 | 06:38 PM
87LB9B4Z's Avatar
Car: See ID
Engine: See ID
Transmission: M39
There's also the cold start valve. I figure mine needs to be replaced. Way too many revolutions before the motor fires.
Old Apr 17, 2002 | 06:21 PM
Dingus's Avatar
I've checked around the fuel pressure regulator, and everything appears O.K., but I will be checking the fuel pressure this weekend. I've wondered about the cold start valve, but I don't know how to check it. To start the car, it's like starting a carbureted car with an inoperative choke. Would that cause it to run rough under load too?
Old Apr 17, 2002 | 07:22 PM
87LB9B4Z's Avatar
Car: See ID
Engine: See ID
Transmission: M39
I believe the only function of the cold start valve is to "prime" the engine since only one bank of injectors fire half the fuel necessary at a time. Of course I'm no expert, but I think that's how it works.
Let us know what you find.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Bradsaundry
Aug 12, 2015 12:34 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Sherpajames
Aug 7, 2015 06:56 PM
