Injector "dropping" fuel...think this could be the problem??
Old Apr 17, 2002 | 03:36 PM
BAK12484's Avatar
More time screwin around w/ the car trying to see why in the hell it'll randomly shake and backfire. It only happens when the car is under load too. Anyway, my dad was watching the injectors as i stood on the brake and kept it around 1500 rpm - - he said that the injectors were spraying like normal but there were also large drops of fuel coming from them too.....?!?!? Now I am thinking this could be the cause of my problem as the cylinders would be flooded w/ fuel, and the unburnt gas igniting in the exhaust causing the backfire
Now how can i check to see if its the injectors or something else that's screwing up. Should i get a certain reading if i hook a voltmeter up to the injector wiring harness, if so how many volts? I'd try new injectors but mine are fairly new (replaced w/ the 2500 mile old motor the previous owner put in) and i was quoted $79.99 a piece at Autozone for new ones. Also, the previous owner took out the MAT sensor when he put in the open element filter...could no sensor cause something like this?? Thanks for all the help.
Old Apr 17, 2002 | 06:24 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
You can send them to Rick at Cruisin Performance and he will
test them and if you request flow match them.
bryan623
Mar 22, 2021 06:43 PM
Street Lethal
Apr 30, 2019 12:14 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
tmellott89
Aug 16, 2015 02:58 PM
