Slight Miss, This Has Bugged Me for Awhile
Old Apr 21, 2002 | 03:02 PM
  #51
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
I have had the same miss at idle too. Planning to replace all the ignition pretty soon so I will see if that is it. Doesn't really bother me. Only my jealous friend notices it be he notices anything that might consider something is wrong because he is jealous of the car. You know the type.
Old Apr 21, 2002 | 03:40 PM
  #52
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
well guys I finally solved my problem.I ignored the timing tab on the timing chain cover and set it by ear with The brown and black wire hooked up I started retarding the timing and it started getting smoother.The engine is a rebuild from some remanufacturer and I guess that timing tab may be in a different location.I went for a run and it really doesn't feel much faster but it doesn't miss a lick at idle.I'm making a reference point from where it's at now and gonna start tweaking on it.Man I wish you guys well cause I know this is some frustrating stuff.If you suspect your timing tab is not the original don't trust it!!!!!!!!!!!!:rockon:
Old Apr 21, 2002 | 05:01 PM
  #53
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Originally posted by mystikkal_69
timing being a little advanced will cause a slight miss in some cases
looks like your case was one gmgod.
Hotrodboba400
Dec 10, 2019 07:07 PM
92-Formula
Dec 12, 2015 10:34 PM
Antips16
Oct 30, 2015 06:42 PM
jerflash
Sep 23, 2015 09:21 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
