Canister Purge vac valve buzzing....
Old Apr 17, 2002 | 09:08 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
quite loudly at idle. When I just blip the throttle it quiets down. Also when I pull the electrical connector, it stops buzzing. I know the ECM controls it, and possibly at a duty cycle. Just not sure why it is making all this noise at idle. Could the little vac valve be bad? Didn't do this last year, but I did perform some major porting work on the base/runners/plenum this winter. I am also sure that everything is hooked up right.
Just kind of anoying really, not sure if it is doing any harm.
Old Apr 19, 2002 | 08:32 PM
Car: 1988 IROC-Z
Anyone have any ideas? Is the solenoid bad, or the little purge valve? When I just blip the throttle it quiets down. Maybe I should just leave it unplugged..
pjsparts
Oct 29, 2025 06:39 PM
69GTOby
Apr 18, 2016 02:34 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
sandman92084
Sep 12, 2015 10:27 PM
