removing emissions
Old Apr 18, 2002 | 01:52 AM
FLfirebird's Avatar
removing emissions
I want to take the emissions junk and charcoal canister off my '92 firebird 305 TBI. I am just wondering how hard it is, and what exactly I need to take off or plug up, or whatever so it doesn't screw anything up!
Old Apr 18, 2002 | 02:29 AM
Jza's Avatar
Jza
Hey, how's everything? I'm in P'Cola as well.
It's not too hard to remove the emissions equipment, just time consuming if you're impatient. The main component and first thing you'd remove is the AIR pump. Here's an article on removing it that would apply to a 92.
How to Remove Your Smog Pump From Your Serpentine Belt Equipped Third Gen
Then you start following hoses from that unit and pulling them out. It'll go to the AIR divert valve. You can just unplug the electrical connectors and tie them out of the way somewhere. Then one hose goes to the AIR port manifolds on the exhaust manifolds. You can remove all that, and plug them with brass plugs that you can find easily at a hardware store. The other hose from the valve goes down to the catalytic converter. You'll have to remove some hard to get to bolts to get the hard lines out, and will most likely have to cut the connection at the cat (it's usually so crimped you can't slide it off). If you think you might ever reinstall it in the future, then instead of cutting it across the pipe, make a cut lengthwise along the crimped area so it'll expand enough to slide off. That way it can easily be rebrazed or welded back on later.
Welcome to the boards.
Old Apr 18, 2002 | 11:49 AM
FLfirebird's Avatar
Thanks for the help, and thanks for the welcome!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
89fast5oh
Sep 8, 2015 09:55 AM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
