Really wierd noise
Old Apr 18, 2002 | 04:51 PM
FaQBeatch36's Avatar
Really wierd noise
I have an 86 Camaro, 305 Carb. Whnever I am at at a stop and try to take off I get noise coming from my passenger rear tire. It is not a wheel hop, but is sounds like the suspension or something is broke. If I stay on the gas after about four seconds it sounds like my tranny is hitting from side to side. If I take turns a little fast, like a left hand turn at 20 it sounds like my tranny is hitting again. I have looked at the rear suspension and at the tranny mount and it looks fine. I have looked at the motor mounts but I really don't know what I am looking for. If anyone knows what might cause this I would really like their help. Thanks
Old Apr 18, 2002 | 06:53 PM
Anyone???
Old Apr 18, 2002 | 07:01 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Tranny mount is broke. Relatively easy to fix. Cheap too. $20 bucks for an aftermarket polyurethane one, but some people complain that they transmit too much vibration to the interior of the car. Stock replacements are about $10 and break easy but are rubber and don't vibrate the cabin. All you need to do is get under the car, unbolt the old one, lift the tranny with a small jack or something, put new one in, bolt it to tranny, lower tranny, bolt to crossmember.
This happens to ALL thirdgens at one time or another. VERY common.
Old Apr 18, 2002 | 07:28 PM
Ok I will check it again. Thanks for the help..... It should be realitivly easy to fix, right??
Old Apr 18, 2002 | 08:29 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yep, trans mount..
mud runner
Nov 2, 2015 07:30 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
lanceflame44
Sep 25, 2015 12:28 PM
andy74
Sep 3, 2015 08:41 AM
