What Can I Salvage ???
Old Apr 19, 2002 | 08:51 AM
Tbird's Avatar
Yesterday I found out my 305 is pretty much junk and isnt worth to fix, so I am going to buy a 350 block My question is what can i salvage besides the carb to use on the 350 to save money.....
Old Apr 19, 2002 | 10:36 AM
Vader's Avatar
Intake, water pump, all accessories, pans ans covers will fit a 350 and shouldn't be any problems.
Other parts may be reused if they are aftermarket replacements or relatively new and in good condition, such as rocker arms and push rods, roller lifters and cam, flexplate, oil pump, distributor, hoses, crankshaft, connecting rods, tiiming set. Of course, if these are stock parts or worn, they should not be reused. If you are buying just a replacement short block, some of these items can interchange.
Not a lot else can be recycled to the 350. Don't reuse the balancer, main caps, piston pins.
Old Apr 19, 2002 | 10:47 AM
Tbird's Avatar
Ok thank I thought i could but wasnt sure, Does anyone have any recomendation on heads or cams...
hartsmike
Oct 4, 2015 01:00 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
Fox118
Sep 1, 2015 04:07 PM
draco
Mid-West Region
Aug 10, 2015 09:18 PM
