Cam Recommendations/Trick Flow heads
Old Apr 19, 2002 | 09:14 AM
ORAY777's Avatar
Any you guys have any ideas on what cam to run with my Trick flow 23 degree heads? Right now i'm thinkin of getting the TPIS base and runners. Probably going with SLP 1 3/4 headers.
Old Apr 19, 2002 | 09:31 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have the 23*'s edelbrock base and asm runners. I went with the xtreme 218/224 .495/.503 112 LSA. I running the stock chip. It runs better with the stock one vs the ed write one.
Old Apr 19, 2002 | 11:17 AM
iroc22's Avatar
Keep it around 220*-225* and you'll see big power increases without sacrificing driveability
Old Apr 19, 2002 | 04:48 PM
Blackened's Avatar
I have the same heads and HAD TPI. It ran great with a 220/230 cam at 0.050 and around .510 lift. This was with a 350.
Old Apr 19, 2002 | 05:13 PM
Scrams84Z's Avatar
Car: 1984 Z28
Engine: Custom built 383
Transmission: Tremec 3550
Im running the XE284 on my 383 with Trick flow heads. Nice cam. A little lope at idle but sounds WAY cool. Still pulls about 14 mg vaccum.
gta90
Sep 15, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
michealleger
Aug 26, 2015 03:29 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
