Largest REAR Tire on a Lowered GTA 16" Rim
Old Apr 19, 2002 | 09:47 AM
Night Hawk's Avatar
What is the largest REAR tires I can fit on my lowered 88 GTA with stock 16" GTA rims without making any modifications to the wheel well or anything else? Would 265/45-16's work? My fronts are curently 245/50-16's.
Old Apr 19, 2002 | 04:44 PM
Beefy89's Avatar
I believe 255/50/16 is the biggest tire you can put on that rim...
Old Apr 19, 2002 | 05:32 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Wrong you could put even 275mm wide tires on an 8" rim safely, you might be able to get away with 285 mm wide tires if your crazy! The tires your thinking about might fit?
Old Apr 19, 2002 | 06:56 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The problem is finding a DECENT tire in a 16" that is larger than 255. I forget who use to make a 275, but it wasn't a great tire.
There also was a greater selection 10 years ago than today. Unless things have changed in the last 12 months that I looked, you pretty well are stuck with with 255/50/16s as the largest available in a GOOD tire.
Old Apr 20, 2002 | 05:49 PM
2ponchos's Avatar
i have a set of mickey thompson sportsman pros that are 27x11.5x16 that i have on my gta rims and the rear is lower by bout 1.5-2 inches they stick out a bit but i also had to massage the inner wheel well a bit and i have a set of 275r16's for the street on there they are only bout a .5 inches narrower than the pros so u can get a wide tire ont here.. just my input hope this helps
eightsixseven
Dec 16, 2024 01:50 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
