Valve Seals
Old Apr 19, 2002 | 12:57 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Valve Seals
How hard is it to replace the valve seals on my 305 Z-28 with the engine in the car? How do you go about it? And do i need any machine work or special tools?
Thanks, i would like to fix the smoke at startup issue.
Old Apr 19, 2002 | 01:44 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Not to hard but time consuming.
First remove the vavle covers and spark plugs. You'll need a air compressor feeding about 6 psi through the lines. You can buy a part the hooks up to an air line and screws into spark plug hole. This will keep the valves up inside the head. If you don't have this then I'm not sure how else to keep them from falling on top of the piston. Maybe someone has another suggestion. Anyway, Take the rockers off, the keepers and retainers, remove the spring (You'll need a valve spring compressor for all of this). Then use a valve seal remover and replace the valve seals. This is the basics. Then of course install everything back on.
Bubbajones_ya
Jul 6, 2024 08:32 PM
355tpipickup
Sep 13, 2015 11:35 PM
bamaboy0323
Sep 12, 2015 07:14 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
tgp1990
Sep 4, 2015 06:24 AM
