electrical question
Old Apr 19, 2002 | 05:40 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
electrical question
ok,i direct wired my rad fan into my fuse panel so its always on with the key, i then(probly a bad idea but i took a short cut) connected my power wire from my tranny cooler fan to this same wire, i just peeled back the casing and "t"ed it in.........i know i should have 2 seperate wires but heres the deal , its been this way for 2 years with no probs, today i take the car out for the first time since last year and the wire is emitting a high pitched hum and when i touch it it is vibrating and this is with the key off?????? it isnt getting any power with the key off and only the part passed the "T" is humming not the whole wire.....why would it all of a sudden do this?
Old Apr 19, 2002 | 05:48 PM
wasp's Avatar
just a low down on what wire im using , i got it at radio shack......its 12 awg the spool says "hookup wire"
tech.data:600v,80c,1/32 pvc
wrong wire maybe?
Old Apr 19, 2002 | 09:03 PM
wasp's Avatar
ummmmmm
Old Apr 19, 2002 | 09:53 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Is it vibrating only when the fans are on or spinning down after shutoff? Start at the fans and see if one of them are vibrating. If not, rewire them correctly and zip tie the bloody things.
Old Apr 20, 2002 | 05:16 AM
wasp's Avatar
nope , vibrating after everything is shut off, does it for about 20 minutes then it stops..........gonna rewire them seperately, i thought maybe somone could tell me why it does this, i bet its resistance of some kind
MustangBeater20
Oct 29, 2022 09:20 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
