High Milage engine oil....questions
Old Apr 21, 2002 | 05:16 PM
iroc_cragg's Avatar
Hey
has anyone ever used that higher milage engine oil. What does it do, will it help out my car any or just mess it up. Would I be better of going with regual 10w 30 or 5w 30 compared to the higher milage engine oil.
Old Apr 21, 2002 | 06:10 PM
idrag2's Avatar
My buddy at work starting running Val. Max Life in his 90 S-10 with 160,000 on it. As soon as he changed the oil it started to smoke.............so he drained it out after 3,000 miles and switched back to GTX 10-40 and it quit. So you can go from that......IMO
Old Apr 22, 2002 | 07:07 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
High mileage oils typically have more polymers to keep the oil thicker at operating temps. Polymers provide the viscosity when the oil heats up, but fewer are better overall. Excessive polymers can cause ring sticking and leave deposits in the engine. If your engine was OK with the oil you were using then just go back. If an engine is old and puffing there is not much any oil will do to circumvent this. I think this high mileage stuff is just marketing more than anything else. Just my 2 cents.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
