Speedo Calibration
Old Apr 21, 2002 | 07:30 PM
Trent257's Avatar
Speedo Calibration
i went from 2.73 to 3.73 gears, where can i get my speedomiter calibrated?
also my speedometer only goes up to 110, if i photoshop it and change the numbers around, can i get it calibrated to the new numbers?
how much does calibration cost
Old Apr 21, 2002 | 08:42 PM
idrag2's Avatar
Just by the speedo gears, around $20.00. If you go and look in the tech articals it will tell you what gears to use.
Old Apr 22, 2002 | 02:36 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
For a 700R4 automatic you need a 15 tooth and 45 tooth speedo gears. They go in the tailshaft of your transmission.
For the speedometer, you have to replace it with the one you want.
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
