what timing for best mileage?
Old Apr 24, 2002 | 03:40 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
I'm driving my car 220 miles this weekend to bring it to school so i want the best mileage, my timing is now -6 but i'm planning to put it at -10, should i leave it at -6 for the way up? or does timing not affect mileage?
Old Apr 24, 2002 | 05:12 PM
89BlueTA's Avatar
Did you get your valvetrain problem solved?
I would say the 10 deg, would give you better mileage, if the motor is making more power more efficiently. Then you should get slightly better mileage, though probably not very much.
GL
nick
Old Apr 24, 2002 | 05:50 PM
Car: '87 Camaro LT
Engine: 355 L98
thanks blue. and yeah i fixed the valvetrain:
when i put the new timing set on, i aligned the cam gear dot to the 0 right above the keyway on the crank gear instead of the 0 that's three teeth in the counter clockwise direction. so i fixed that and put the driver's head back on w/clay on the piston, i now get .252" of clearance between valves and piston.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
dutch930
Sep 11, 2015 06:58 AM
NBrehm
Aug 25, 2015 11:49 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
