Spark Plugs and full MSD Ignition system
Old Apr 24, 2002 | 03:40 PM
1982Camaro383's Avatar
I have a 1982 Camaro with a strong 350 chevy MSD Ignition. What are the best plugs that I can use with my MSD System. I am using platinum but I am taking them out because the plating chips away with the MSD. What plugs are recommended for this ignition. The Heads I am using are the GM Performance Parts Drilled and Tapped Vortec Heads. I am also using headers, for info on engine and the below link. Any help would be greatly appreciated.
Old Apr 24, 2002 | 03:41 PM
http://www.fbody.com/members/82Camaro
Old Apr 24, 2002 | 04:08 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Regular AC Delco should be fine.
Old Apr 24, 2002 | 08:40 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Harwood Outlaw Z Fiberglass 4" Cowl Induction Hood
Hey, you got any pics of your hood ? I just ordered the 2.5 . Did you have to do much trimming? did you use pop rivets or what? any info would be helpful. Thanks
Ron
just reread you post, you have the whole hood huh?
Old Apr 24, 2002 | 09:51 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Yeah I had the same problem with the Platinum plugs using an MSD. IM using AC delco plugs now and they seem to be working fine.
Old Apr 24, 2002 | 09:57 PM
Car: 99 Formula
Axle/Gears: 342
Also, copper actually conducts better than platinum though platinum will last longer.
9192camaro
16
Feb 3, 2019 12:21 AM
evilstuie
Feb 28, 2016 03:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
db057
Aug 22, 2015 08:17 PM
