Where does wireharness for MAT plug into??
Old Apr 24, 2002 | 06:13 PM
BAK12484's Avatar
Ok I got my new MAT relocaiton kit today, but for the life of me can't find where to plug the wire harness into. I found the end where the MAT sensor is located, but since the previous owner did a ****ty job w/ the wire loom, i can't see where the hell it leads to... if anybody could help me it'd be appreciated. Thanks
Old Apr 24, 2002 | 07:28 PM
BAK12484's Avatar
anyone??? i'd like to get this thing replaced tonite
Old Apr 24, 2002 | 10:06 PM
Guest
Guest
Posts: n/a
I'm not sure what the kit you have is supposed to plug into. Its either an extension that you just plug into the connector that plugs into the MAT, or you hook up to a connector that should be about 10" downstream of the MAT towards the firewall, should be somewhere around the distributor where that connector is.
Old Apr 24, 2002 | 10:28 PM
BAK12484's Avatar
its the relocation kit from TPIS. It's the entire wire harness; one end has the MAT sensor attached to it, and the other end has a plug that goes to the connector. I'll try and pull the wire out of all the loom and see where it leads, but i'll make sure to check along the firewall for the connector...thanks
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
