What should I do?
Old Apr 24, 2002 | 06:53 PM
SlowStangEater's Avatar
What should I do?
Just how fast can I go with everyones help????
Ok Im wanting to turn my 305 TBI into a little speed demon. Of course Its not going to run 9s or anything but I can't take anymore 14s and up. So what should I do. I want to hear everyones input before I do it. Ive got a new 305 waiting to be dropped in. I want to do what I need to while its out of the car. So fill me in guys???????????????????????? Oh yeah and Im on a limited budget. Very limited. What should I use off the old engine and what should I not?
Old Apr 24, 2002 | 07:10 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Being on a limited budget and speed don't mix well. First get full exhaust headers and cat-back. I'd recommend the Hooker cat-back (sound clip is in the sign), then get a cam, Comp 262XE or 268 depending on whether or not the heads can handle the 268, not sure. Do some head work either buy a home porting kit or buy some el cheapo heads, I'll let some others give you advice there. And get some gears to match the rest of your setup, most likely 3:73s would be a good choice.
Old Apr 24, 2002 | 07:14 PM
Ok......Well I already have all new heads and pistons and I currently have 373s in my car. So thats good. When you say "do some head work" were you meaning fix up the old ones? As you can see Im not a mechanic by any means...............But Im trying..............
Old Apr 24, 2002 | 07:15 PM
Also what can I do to TBI....................I was told to keep it and forget about a Carb....??
Old Apr 24, 2002 | 07:21 PM
Car: 99 Formula
Axle/Gears: 342
What are the specs on your heads? Int/Exh valve size?
Old Apr 24, 2002 | 07:23 PM
To be honest I dont know. I do know that its all new block and all and its stock so I hope that helps. Im trying to learn.......SORRY
Old Apr 24, 2002 | 07:38 PM
Car: 99 Formula
Axle/Gears: 342
I'm still learning to, you really need to find out the size of your intake and exhaust valve sizes, that will help out a lot.
Hopefully someone with some more expertise will chime in.
Old Apr 24, 2002 | 07:57 PM
I will check it out and get back to you at a later time.......Thanks though
