Dead Bird
Old Apr 26, 2002 | 12:40 PM
BADBIRD87T/A's Avatar
Dead Bird
I HAVE A 87 305 TPI , TO DO A TUNE- UP I WILL NEED TO REMOVE MOST OF THE SMOG EQUIPMENT. IF I DO NOT REINSTAHL THE SMOG PUMP AND HOSES WILL IT CAUSE ANY PROBLES WITH THE COMPTER OR FUEL INJECTION OR MAKE THE CAR RUN DIFFERENTLY THEN WHEN THE EMMISSIONS SYSTEM WAS COMPLEAT.
Old Apr 26, 2002 | 12:52 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
no https://www.thirdgen.org/newdesign/t...rpentine.shtml
Old Apr 26, 2002 | 01:24 PM
NOW I CAN GET RID OF THE SMOG CRAP
THANKS FOR THE INFO
I WENT TO THE WEB SITE BUT I DONT THINK MY CAR HAS A SERPINTINE BELT
Old Apr 26, 2002 | 03:45 PM
Vader's Avatar
87,
I'm not sure what you're calling "smog equipment", but you shouldn't have to remove anything that is emission related to change plugs, plug wires, distributor cap, rotor, clean the throttle body and IAC, set the timing, set the minimum air position and TPS voltage, replace filters, etc.
What in particular seems to be in the way of a "tune-up"?
87v6Bird
Jul 1, 2018 04:12 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
92projectcamaro
Sep 29, 2015 07:07 PM
raymondandretti
Sep 27, 2015 06:43 PM
