Knock Sensor on LG4...
Old Apr 30, 2002 | 09:25 AM
84TAProject's Avatar
Where is the knock sensor located on a 1984 LG4? I dont know where it is, and I just got the 350 in my car. It almost feels like the car is retarding my timing when i get to like 2800 rpm and then advancing it at like 4000. Almost feels like it hesitates at those points. What kind of knock sensor would I put on? The only one for a 350 that year I could find is off of a corvette. Of course knowing my luck there is no knock sensor on an 84 and its all in my head.
Old Apr 30, 2002 | 11:37 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Well, you must know your luck well indeed, because your 1984 LG4 doesn't have a knock sensor.
1982-1984 LG4 motors are not equipped with a knock sensor. 1985-1987 LG4 and all L69 motors are.
That answer your question?
FYI, it's all in the PROM. Do you still have the original 1984 LG4 PROM?
Old Apr 30, 2002 | 02:37 PM
I still have the original LG4 PROM. What kind of PROM should I get for it and would it really make much of a difference? I dont want to run high test gas with the bird, my minimum wage job can barely handle 87.
Old Apr 30, 2002 | 02:39 PM
99Hawk120's Avatar
If you've got a minimum wage job, stick with the stock PROM. Every other one I know of that's even remotely useful requires premium, because it advances timing (that's about all the ECM does anyway).
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
