weight difference
Old May 1, 2002 | 01:08 PM
PAformula's Avatar
weight difference
how much more does a 350 weight compared to 305 with the same induction setup?
Just curoius,
thanks
Old May 1, 2002 | 01:40 PM
BenDoe91z28's Avatar
theoreticly a 350 would weigh less because it has a larger bore. lets do some math here.... 350-305=45 so it looks like about 45 cubic inches of steel, plus whatever the size increase in the heads intake runners are... maybe a 350 weighs 25 pounds less???
Of course to be the devils advocate, maybe they use stronger crank/pistons/rods to counter it.. i guess it depends on your engine.
EDIT: its not going to be 45 cubic inchces of steel because they probably keep the same distance between the bore and the water jacket. maybe it weighs about 10-15 pounds less
db057
Apr 28, 2019 07:45 AM
BAMiller
Sep 14, 2015 06:38 PM
roysatikas
Sep 7, 2015 08:08 PM
SG91camaro
Sep 5, 2015 10:27 PM
greenyone
Sep 2, 2015 03:39 PM
