Cleaning Spark Plug Wires
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
What do u guys use? I don't want to damage the wires or anything. Thanks
Car: 99 Formula
Axle/Gears: 342
Never heard of that before, mine don't really get dirty. I put some heat sleeving on them and that stays clean too.
Engine: 3.8
Axle/Gears: Dana 60
Your kidding right? These wires costed me 60 bucks. (MSD 8.5mm Superconductors) There just a little dirty guys, I am just wondering which products could I use and couldn't use to wash them. Don't want to ruin them ya know.
Hand cleaner works the best and will not do any damage to the wires. Any "parts cleaner" or solvent will damage the wires over time, especially if you do it a number of times. I clean mine often. They are yellow wires!
Car: 1986 Firebird
Engine: 2.8 V6
I usually do it in two stages, with a sponge and a rag. I take a wire off, and wipe it with a damp (water) sponge to get most of the dirt away. Then I spray some windex on a rag, and wipe the wire clean. Takes 30 seconds a wire? I have the MSD 8.5mm wires too, and after a few months of driving, they're dusty as all hell.
Car: 87 Formula
Engine: 327
Silicone spray may work. And theres no way its going to hurt a silicone wire. Mechanic friend showed me one time how it lifts grease from paint. Just dont try repainting any time soon!
Car: 1986 Firebird
Engine: 2.8 V6
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I also recommend hand cleaner or simple green.
I've had the best luck with the orange gojo hand cleaner.
Hey, when you're finished your hands will be clean too!
-Rich-
-Rich-
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I have always dipped a rag into clean, new trans fluid, and wiped off the wires. If you rub hard, it will take off the lettering if any is on the wires.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
