SR 305 torque heads on a 350?
Old May 2, 2002 | 08:58 AM
TBI305Camaro's Avatar
i asked about this once before but i wanted to know something else...i noticed most of GMs crate motors come with the smaller valves and make good power so wouldnt the SRs make good power on a 350? i plan on getting them and having them ported before they go on my 305but when im ready maybe put them on a 350...also with the smaller valves couldnt you run a high lift cam without valve shrouding...would that be good or bad?
Old May 2, 2002 | 11:00 AM
iroc22's Avatar
Valve shrouding on a 350 with 2.02/1.60 valves is only eminent at lifts past .550" (are you gonna go that far?)
A ported set of S/R 305 Torquers will work just fine on a 350. They're the same as the 350 Torquers just at 58cc chambers. So you're compression will be bumped up a lot.
Just a FYI, my school drag racer uses S/R Torquers 67cc heads 2.02/1.6 valves , ported and polished, 230* cam with .480" lift and it makes 450hp at 7000rpm. It's in a Vega too. This car is a real piece of work.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
