Aaaaarrrrghhh.... no start!
Old May 3, 2002 | 08:22 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
A couple of days ago, I replaced my injectors. I can't get the engine to turn over since. I've looked into everything I can think of, including:
Fuel pressure (50 psig)
Spark (attached timing light and it flashes during starting)
Disconnected MAF
Replaced ignition module
Cold start valve functional check
Disconnected the timing reference wire
Checked all fuses
No EGR so didn't worry about this one
I even got back down to the fuel rail, pulled it off the intake and cranked to see if I was getting fuel. They are firing. Also, I suspected a vacuum leak but the engine should still start, then run rough. It gives no hint of wanting to start.... just cranks and cranks.
So the bottom line is I believe I'm getting spark and fuel. What else could cause a no start?
Willie
Old May 3, 2002 | 09:30 AM
Vader's Avatar
Double check the spark plug wire routing and connections:
Old May 3, 2002 | 06:02 PM
Willie's Avatar
Jeff,
I appreciate your help but I didn't touch my plug wires. I have a feeling the injectors aren't supplying enough fuel to fire up the engine. Earlier, I sprayed some starter fluid into the plenum and it started. It ran but it backfired through the exhaust. I killed it then.
I also temporarily swapped in the ECM out of my functional convertible. It did not help.
Willie
Old May 3, 2002 | 06:05 PM
iroc22's Avatar
I think if the firing order was out, it would backfire through the distributor when you try and crank it.
Old May 3, 2002 | 06:15 PM
Guest
Guest
Posts: n/a
Did you check the ohms of the new injectors? Long shot I know, but if they are way off I suppose they might not work right.
Old May 3, 2002 | 06:35 PM
Vader's Avatar
Hey, Wille....
I don't s'pose you have a 'noid tester or o-scope? Just to make sure the injectors are getting pulsed...
No cold start injector, right? (Later than '88)
Old May 3, 2002 | 11:00 PM
Hulk0202's Avatar
Try some other injectors.
Old May 3, 2002 | 11:18 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'm with Vader, check to see if the injectors are firing...also, quick check to see if 12v's is there and and you haven't burnt the INJ1 and INJ2 fuses.
You couldn't have crimped the injector harness somewhere when putting it all back together? May want to check both sides of the plug to ground..could be a short.
Starting fluid indicates you're not getting any fuel.
Old May 3, 2002 | 11:39 PM
Willie's Avatar
Guys,
I really appreciate all your thoughts. They are all good ones. Fortunately, I figured it out tonight (finally after three days!!).
Jeff, you're not going to believe how stupid I was. I decided tonight to reinstall my original ignition module. Upon reinstalling the cap and wires, I discovered that I did screw up the firing order!! (Go ahead with the "I told you so"......) My four wire retainer for the driver's side bank of wires somehow got inverted, so what I perceived to be the #1 wire was actually the #7 wire, and so on..... What a dufus I am.... live and learn.
Again, thanks for all the input to all of you.
Willie
Old May 3, 2002 | 11:41 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Originally posted by Willie
Jeff,
I appreciate your help but I didn't touch my plug wires. llie
Hmmn, I think someone/something was getting blown...beside the car..
Old May 4, 2002 | 08:13 AM
Willie's Avatar
Well, you know what they say about getting old. The first thing to go is your memory..... or is that the second? I honestly didn't remember pulling my driver's side plug wires to get them out of the way to remove the cold start injector tubing off the fuel rail.
Willie
Old May 4, 2002 | 09:01 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
And people wonder why we harp on the basics
Old May 4, 2002 | 10:17 AM
Willie's Avatar
Yep, I'm a classic example.
Through it all, I did test the new injector resistances, I did replace them with known good ones, etc. All in all, I did all the labor to get to the injectors a total of SIX times. All because I had four plug wires goofed up.... Well, at least I admit to it and smile about it (now anyways). This is one I'll always remember.
Willie
Old May 4, 2002 | 10:57 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
No biggie, I remember ***** (name deleted on purpose) pulling his head looking for a miss, turned out he had two wires swapped.
Old May 4, 2002 | 11:04 AM
Ed Maher's Avatar
Car: 04 GTO
Same thing happened to uys last year at the macgathering in ohio. A girl with a TBI 350 was complaining that something just wasn't right with her car after we did an oil pressure sending unit swap.. We went nuts going over the whole thing a million times, and i'm talking there were probably 5 or more of us 'old-timers' there scratching our heads.
We finally exhaustively checked the firing order instead of just quickly looking at it. Turned out to be 2 wires switched up on us after all....whoops. And nobody rememebered screwing with the wirers that time either, lol, famous last words i guess
Old May 4, 2002 | 12:10 PM
gruveb's Avatar
Car: 1989 IROC-1
I've done the same thing. It drives you absolutely batty! Next time something happens you're going to go over the firing order time and again doubting yourself and it will be something else equally as simple!
At least that's how those things play out for me.
But then again, I'm slow!:lala:
Old May 4, 2002 | 01:00 PM
Willie's Avatar
As a friend of mine once said, "If you can't laugh at yourself, you're taking life too seriously." I truly hope we're all laughing. I am.
Willie
Old May 4, 2002 | 05:24 PM
Vader's Avatar
Hey, Willie -
I'd hate to even try to remember how many times I've done the "5-7 swap", telling myself "I know I've got the order right..."
So? Did the new injectors do any good?
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
