350 Tpi
Old May 4, 2002 | 07:27 AM
jeff85iroc's Avatar
350 Tpi
Hey guys
my question is could i put a TPI setup from a 85 camaro 305 onto
a 84 corvette 350 long block without having to get anything drilled out.
I've read on here some heads don't go with some manifolds.
anyway shold this work.
Jeff
Old May 4, 2002 | 10:13 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I think you'll be fine, not positive though, Vortech heads won't go with a stock manifold. Not sure when they went to centerbolt valve covers, probably after '86 at least, that might cause some problems too, but you have an '85.
Old May 4, 2002 | 10:54 AM
jeff85iroc's Avatar
Thanks mark
It should be ok the changes started i THINK in 87.
But i will soon find out.
Jeff
Old May 4, 2002 | 12:43 PM
iroc22's Avatar
Ok it will bolt up just fine. Make sure you match the pph of the injectors for the 350.
87-92 F-Bodies were updated intake pattern (two center bolt holes were more upright).
85,86 F-Bodies were the standard pattern (pre 86).
85-91 Vette were the standard pattern (pre 86).
Centerbolt covers started in 87. The Corvette got the centerbolts but retained the old intake pattern. Cast Iron got the updated pattern. Hope that clears a few things up.
Old May 5, 2002 | 01:11 AM
jeff85iroc's Avatar
Thanks for that
At least i can go ahead with the swap and put my 350 in.
Thanks guys.
Jeff
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
