Having Major Problems ....Need Help
Old May 4, 2002 | 02:28 PM
indocld's Avatar
Well the car is a 91 Z-28 w/ a 305 TPI 5 Speed . I am having a code 43 and the car is running poorly.............. So the thing is I have changed the knock sensor , the wire to the knock sensor from ecm , The ecm and chip, and have done a full tune up. Also checked for exhaust leaks and other bad wiring and I cant Hear
any noise coming from the engine or around it. So any ideas would greatly be apriceated .........Thanks
Old May 4, 2002 | 03:42 PM
Vader's Avatar
Indo,
Welcome Aboard!
Have you tried to analyze/inspect the HEI module wiring and connectors? The ESC should be built into the ECM on a '91, so the communication for timing advance is directly from the ECM to the distributor. Check the large flat Weatherpak connector from the distributor for connections, damage, or corrosion. You may also want to remove the distributor cap and rotor to inspect the connections at the HEI module itself. Especially watch for pinched, burned, or otherwise grounded wires.
Old May 5, 2002 | 12:36 AM
indocld's Avatar
Checked it all out all looks fine to me , but to you think it is worth a chance to change the HEI . Forgot to add it has 2 mechanics stumped.
Old May 5, 2002 | 10:45 AM
Vader's Avatar
Exactly what was involved in your "full tune up"? That is, what was replaced, cleaned, tested, or adjusted?
Old May 5, 2002 | 01:22 PM
indocld's Avatar
The spark plugs, wires, distributer cap and rotor, coil pack, belt, and most changable fluids and timing was also checked it is 6 degrees....................air filter and pcv valve were changed 2 months before this
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
mrdevontay
Sep 2, 2015 08:04 PM
greenyone
Sep 2, 2015 03:39 PM
