PCV valve
Old May 4, 2002 | 07:57 PM
82T/A powah's Avatar
PCV valve
i recently changed my PCV valve on my 82 TA and i noticed the old only had to ends to it.. one end went into the valve covers and the other end went into the hose that it connects too.. now the new one i got has those same 2 ends but also has one that sticks to the side.. when i put my hand on it, it seemed like it was suckin in air into the valve cover.. i believe the new one looks right but whats with that old one? was it not the proper one? maybe that cause my car to develop the worm piston rings or soemthing.. not getting proper air flow in the engine..? heh i dunno
Old May 4, 2002 | 08:30 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Some aftermarket PCV valves have more than one hose connection.
Just use the one you need, and cap the other.
Old May 4, 2002 | 08:33 PM
kewl man. didn't know that.. so shoul you cap the other or does it not really matter? right now it's just suckin in air into the engine.. or valve cover i mean.. which doesn't sound like a bad thing.. i mean more air the better right? i think..
Old May 4, 2002 | 08:36 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Cap it .....its a vacuum leak.
Old May 4, 2002 | 10:02 PM
Vader's Avatar
Cap it before you go lean and burn a piston...
tyeo098
Nov 30, 2015 06:27 PM
sleprock
Sep 24, 2015 04:33 PM
CatmanFS
Sep 19, 2015 09:00 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
