starting motor up for the first time
Old May 6, 2002 | 01:11 PM
83z28500ci's Avatar
whats up guys. before i start this motor up i need to know to what point i should tighten these roller tip rockers to? the heads,cam,lifters.and rockers have 0 seconds on them, should i tighten them up al the way to the point were i can turn the pushrods? or do what? id like to get it started tonite.
Dan
Old May 6, 2002 | 07:13 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
prime the oiling system and the adjust all rockers to have .030" preload
Thats depressing the plugger in the hydraulic lifter about the distance of a plug gap. Comp uses this as their preload spec.
Make sure you do it cyl by cyl. Rotate the motor around by hand to get the cam lobe on the base circle. Pull a few plugs out to help turn it over.
good luck
Old May 7, 2002 | 10:24 AM
Beefy89's Avatar
Like jcb says,I did mine one at a time.
I tightened mine till there wasn't any up and down play,but I could still spin it,then I went a 1/4 turn........
Old May 7, 2002 | 11:50 AM
83z28500ci's Avatar
thanx alot guys. im gonna try my best to make it come to life today. got 7 hours of sleeep
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
