what combination of heads, cam is the best on TPI???
Old May 6, 2002 | 07:38 PM
Don_89Iroc's Avatar
im looking into buying a 350 4bolt block bored .030 over, for putting my TPI on, i wont be running stock inj. or tpi base, runners, or plenum, i was wondering a good combination of head's and cam and roller rocker's to top it off, and i want to run at least mid 13's but 12's would be good too
Thanks -Don
Old May 6, 2002 | 07:46 PM
rezinn's Avatar
"But 12s would be good too" sure would!
What intake are you planning on running? Sounds like you're just looking for a good combo that's been used?
Old May 6, 2002 | 07:58 PM
Don_89Iroc's Avatar
be running a ported base, not sure which brand yet, yeah if anyone knows a good combo it would help me alot
Thanks -Don
Old May 6, 2002 | 08:16 PM
IROCracer's Avatar
I'd use a TPIS ZZ-9 cam with a Mini ram. Sharp makes awesome roller rockers. That's be a mean *** setup.
Lotta money involved there though.
Kelly
Old May 8, 2002 | 12:57 PM
Don_89Iroc's Avatar
what other combination's are good?? ive heard alot about afr 190, and 195 head's and the zz4 and other cam's but im wondering what combination would be good, for running high or mid 12 seconds if im running w/ ported base runners plenum exc.exc...????? Thanks -Don
Old May 8, 2002 | 01:19 PM
Little GTA's Avatar
Accel 74219 cam...
Aluminum heads (AFR 180s would be great) 10.5-1 compression
LTRs, ported base or Accel base, ported plenum
mid 12s with proper tune, better on some vehicles depending on weight, gear, etc.
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
anesthes
Aug 8, 2015 09:37 PM
drathaar907
Aug 6, 2015 04:20 PM
