Early manifold on '87 up heads.
Old May 7, 2002 | 09:44 AM
PerthZ28's Avatar
What's the best way to modify an early manifold to suit the different middle bolt angles on the 87 and up heads? Is it best done on a mill, a drill, with a file, dynamite or what? Any pics?
I believe there is an Edelbrock manifold that is set up for both angles - anyone have any pics so that I can see how they did it?
Is the angle of the centre 4 bolts on the new heads 73 degrees [as opposed to 90 degrees]?
Old May 7, 2002 | 11:37 AM
tpi_roc's Avatar
summit/jegs sell little pieces that slip into the holes and act as a "guide" for your drill bit (hand drill) for the new angle....
heck its just fine to shuv a drill into it and "waller it out a bit"
Get shady tree mang
Old May 7, 2002 | 06:55 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
If you do that, the bolt heads won't sit flat on the intake surface.
Is there some way get them to sit flat, other than spending LOTS of time with a dremel...
Old May 7, 2002 | 07:00 PM
tpi_roc's Avatar
Other than a mill, no
The idea isn't to have a flat bolt, the idea is to have it torqued and held to say 35lbs
Whether the bolt surface is flat or not wont prevent it from holding at 35, just make it ugly
Old May 7, 2002 | 08:19 PM
Hellraiser's Avatar
I could've sworn i saw little adapter shims being sold with some of summit racings manifolds that allowed for both bolt hole angles. Check on their site, or give them a call...
Hellraiser
gixxer92
May 18, 2017 11:20 AM
Chas91Z28
Oct 22, 2015 10:12 AM
sreZ28
Oct 22, 2015 08:21 AM
BLK87Z
Sep 18, 2015 11:29 PM
