Air Foil??
Old May 7, 2002 | 09:58 AM
dejaybrian's Avatar
Air Foil??
anyone have this and is it just a hoax or is it a valid part...does it help the engine breathe...i am trying to build up my engine as much as i can without major work...that will come later when i get the money...
Old May 7, 2002 | 10:27 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It is supposed to smooth out the air flow into the TB slightly, thereby increasing flow capacity. The difference is very small, like 2 or 3 HP at most. If you can get one for less than $30 it might be worth it.
Old May 7, 2002 | 10:49 AM
dejaybrian's Avatar
they claim that it adds 10-15hp that is hard to believe...i will spend my 30 dollars on something else..thanks for the info
Old May 7, 2002 | 11:00 AM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Have you looked at the front of the TB? It is pretty nasty with those two gaps. If you buy a new TB it will have that air foil built into it, so there must be a good reason for it. It might actually be worth $30.
Brian
Old May 7, 2002 | 11:13 AM
dejaybrian's Avatar
you do have a point...i spose i could get one it wouldnt hurt...30 bucks for 2 or 3 horse?? thats 10 bucks per horse..not to shabby for ease of installation...
Old May 7, 2002 | 02:33 PM
Vader's Avatar
Originally posted by 89blackGTA
Have you looked at the front of the TB? It is pretty nasty with those two gaps. ...It might actually be worth $30.
Brian
Have you looked at the top of a carburetor lately? It is even more "nasty", with a lot more rough projections and crevices. Not to say that a carb doesn't benefit a little from stacks, but like you said - a LITTLE!
You're right. If you can get one for less than $30.00 and don't have anything else to spend you money on, go for it. If you want a sure gain of horsepower, change your oil to synthetic for the same cost. There is a link floating around somewhere to the SLP site that showed a 10HP gain with synthetic lubricant. The gain figures were measured on their chassis dyno, not taken from an advertisement.
Old May 7, 2002 | 11:28 PM
dejaybrian's Avatar
wont the synthetic oil unswell the gaskets?? oil pan valve cover..or is that an old wives tale??
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
