How The Hell Do I Get My Starter Off My Car!?!?
Old May 7, 2002 | 07:31 PM
Don_89Iroc's Avatar
i got the 2 bolts out of it, that was easy enuff, then i got the 3 set of wires of the soleniod, okay......NOW how the hell do i get it out of there? i have edelbrock headers and 3" Y-Pipe and i cant sqeeze it threw there, and i dont wanna take my header off what can i do??? anybody have a clew?
Old May 7, 2002 | 07:37 PM
BOTTLEDZ28's Avatar
Transmission: A4
Looks like your taking your Y pipe off. i know you dont wanna hear it but thats all that is lef tto do. dont fight with it. just drop the pipe it will be easier putting it back in as well.
Old May 7, 2002 | 08:03 PM
Jza's Avatar
Jza
You didn't mention removing the bracket that holds up the other end of the starter. It's just a tiny (3/8th IIRC) nut. Or you're just talking about getting it out past the headers? I have to undo the bolts that hold the y-pipe to the headers. HAVE to.
Old May 7, 2002 | 08:22 PM
idrag2's Avatar
The starter hole is TIGHT.........but it will come out without dropping the exhaust.......it took me a few tries but I figured it out.
Old May 7, 2002 | 09:03 PM
FstBrd6point3's Avatar
I have the same exhaust on my car and *** only knows the number of times I have had to remove the starter in the last 2 months alone. I never needed to remove the Y-pipe, you just need to move the starter off towards the side of the car and then let it angle down and slip past the y-pipe verticaly
Old May 8, 2002 | 12:36 AM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
I had to change out my starter a couple of times this monthand it can be a real PITA! What you need to do is slide the starter towards the front of the car, and then push the back of the starter up to get it vertical so the nose is facing down towards the ground (watch out for the knock sensor) then rotate it a little and it should come out nose first. If that does not work you can take off the solenoid to get more room.
Frozer!!!
Jan 19, 2024 04:55 PM
milk
Aug 10, 2015 06:26 PM
novaderrik
Aug 10, 2015 12:44 PM
86Base
Aug 8, 2015 01:34 PM
