evap canister
Old May 7, 2002 | 10:19 PM
silver89Rs's Avatar
evap canister
can i remove my evap, if so how can i do this.
Old May 8, 2002 | 12:55 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
yes
Old May 8, 2002 | 06:14 PM
BOTTLEDZ28's Avatar
Transmission: A4
yes you can remove the evap. canister very easily. first thing you need to do is unplug the connector on it, then remove the vacuum lines from it. one of the vaccum lines goes to the TB. you must plug it up with a rubber cap. another line goes to the fuel vent line. i left my fuel line open to vent the tank. i cant think of any other line that is connected to it but if it is a vacuum line you have to plug it up from where it came from. you will not set any codes either from taking it out.
Old May 9, 2002 | 09:24 AM
Vader's Avatar
Make sure you have a relief type fuel cap if you do this.
Old May 9, 2002 | 07:36 PM
BOTTLEDZ28's Avatar
Transmission: A4
Vader, why wouldI need a relief type cap when the vent tube from the tank that was connected to the evap canister is just left uncapped
Quzyle
Oct 15, 2015 03:35 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
shanelique22
Sep 24, 2015 06:30 PM
reactor60
Sep 22, 2015 01:44 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
