Early distributer with late harness... who sells the adapter?
Old May 8, 2002 | 08:34 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've seen some adapters available to use the newer small-cap distributers on Vettes and earlier f-bodies that use the larger distributer with the integrated coil, but I need the opposite. I'm converting to an 87 harness but retaining my 85 distributer. I'd prefer not to cut up the harness because I plan on upgrading the distributer later. Anybody know if this type of adapter is available, or at least if the bare plugs are available so I can build one?
Old May 8, 2002 | 09:38 AM
Hellraiser's Avatar
Re: Early distributer with late harness... who sells the adapter?
All you should really need is one HEI Power pigtail (positive wire into the dstributor), and a connector for your tach. Find the positive wire to the dist. then just cut the old connector off and splice the new one on
I used Summit racing part # SUM-G5210, cost me 5 bucks. =)
Hellraiser
Old May 8, 2002 | 10:46 AM
Jim85IROC's Avatar
Hmm. I was under the impression that all of the connections on the distributer (not the cap) used a different harness plug with the new distributer.
LittleFranks
Sep 17, 2015 12:22 PM
Chuck84TA
Aug 27, 2015 11:14 AM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
Firechicken86
Aug 12, 2015 10:07 PM
mcgarnicle
Aug 12, 2015 04:58 PM
