Codes 42/44
Old May 8, 2002 | 05:41 PM
topdown's Avatar
Codes 42/44
My 87 IROC has Codes 42(EST) and 44(oxy sensor lean). The car's idle drops like it's going to die and then the IAC kicks in and saves it up to 900rpm then it repeats over and over. Any ideas??
Old May 9, 2002 | 08:41 AM
Vader's Avatar
Topless,
What is the TPS voltage at the idle position?
Old May 9, 2002 | 08:59 AM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Review the internal plastic connection in the cranckshaft position sensor. Is firmly attached?. It 's broken?. It´s burned for the engine's heat?.
When was the last replace of this part? In the factory in 1987?.
Regards,
Denis V.
Old May 9, 2002 | 04:58 PM
topdown's Avatar
TPS voltage 0.6 and increasing to 4v WOT. Oxy sensor reading low(180-400max). I ripped off the air tube to the cat and left it open (I'm planning on a new exhaust)...would that cause a lean condition?? I figured it would be far enough downstream to affect the converter.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
