non tech, for chem. project
Old May 7, 2002 | 05:04 PM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
Is there ANYTHING on my car taht is PURE Zinc, elemental Zinc, tahts what i need for my chemistry project, thanks.
Old May 7, 2002 | 07:26 PM
ede's Avatar
ede
i'll say not not pure zinc, but i'd look at the carb, door handles, window crank, and assorted *****
Old May 7, 2002 | 11:05 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You can use 1982 and higher pennys, just grind off the copper plating and the rest is pure zinc.
Old May 8, 2002 | 03:23 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Is this project for school or something else? 'Cause I wouldn't rip my car apart for a school assignment!
Old May 9, 2002 | 08:07 AM
Vader's Avatar
...a mechanical fuel pump housing, wiper motor housing, cruise control base, headlight motor housings and linkage arms, wiper arm bases, belt tensioner housing, etc. There used to be a lot more, before the advent of "structural plastic".
Old May 9, 2002 | 09:18 AM
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
You might try a boating store if there's one around you. Zinc is used on prop shafts to act as a doner material when electrolisis occurs. They need to be replaced on a regular basis.
Old May 9, 2002 | 10:06 AM
MikeS's Avatar
Anything that has a galvanized coating will have high zinc content on the surface.
Old May 9, 2002 | 05:24 PM
86IROCZ's Avatar
Sacrificial Anode
Old May 9, 2002 | 06:02 PM
AlexJH's Avatar
Engine: 5.7L V8
This post reminds me of the Simpson's episode....
'Come back Zinc!'
:lala:
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
