After working on the car all winter Fan wont stop running!
Old May 9, 2002 | 12:02 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
I have the dual electric fans and one never shuts off. I put a new fan switch and it didnt help. Any Ideas? Work done was headers head work, and supention work.
Old May 9, 2002 | 12:35 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Replace the relay. It should be on the firewall on the driver's side near the master cylinder. There are a few different relays there. To figure out which one is the culprit, with the fan running, disconnect each relay one at a time and one of them should turn the fan off when you disconnect it. That should be your bad relay.
Old May 9, 2002 | 03:33 PM
Vader's Avatar
WOW! Not even a break for Christmas? You da MAN!
Anyway, if the relay contacts aren't welded, you may want to take a look at the A/C high pressure fan switch. If that is unplugged (or the sensor has failed open-circuit) the primary cooling fan will run continuously.
Ghettobird52
Jul 5, 2024 11:18 PM
midge54
Dec 27, 2019 04:14 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Leggman1
Aug 6, 2015 04:15 AM
