Worried about oil
Old May 9, 2002 | 07:07 PM
SkyWarrior's Avatar
Car: 1986 Pontiac Trans Am
Engine: 305 LG4
Transmission: Borg Warner 5 Speed
Worried about oil
I'm worried about switching over to synthetic oil. When I change my oil, I get a couple of knocks after start up, when the pressure starts to go up the knock stops and Inever hear it again, until the next time I change my oil, that is. Anyway, I was thinking about changing over to synthetic in hopes of prolonging the enivitable, but I don't want my 190,000mi engine to spring leaks. It doesn't leak a drop now, not one drop! Any opinions?
Old May 9, 2002 | 07:22 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Synthetic won't create leaks, but it might worsen ones that are there.
Old May 9, 2002 | 07:40 PM
82camaro's Avatar
Car: 82 camaro SC
Why switch now, if your current oil is working for ya. A knock after the oil change isn't anything to worry about.
Old May 9, 2002 | 07:59 PM
SkyWarrior's Avatar
Engine: 305 LG4
I'm hoping that the switch will help the engine last longer and perform better. I heard that an engine can have a leak that was plugged by conventional oil, and that the synthetic will re-open the leak. Is this true?
Old May 10, 2002 | 07:43 AM
82camaro's Avatar
Car: 82 camaro SC
It happened on my 91 Jimmy with 150000 miles on it. I switched to synthetic and after 2 oil changes it began leaking from the rear main seal pretty bad, leaving puddles. I switched back probably 3 oil changes ago. It has since stopped leaving any drips, but the pan remains wet. I need to clean it up and see if it is still leaking. Just my experience.
Old May 10, 2002 | 08:41 AM
89WS-6's Avatar
true dat, it is probably just your car warming up. Mine does the exact same thing too.
Hotrodboba400
Dec 10, 2019 07:07 PM
69GTOby
Apr 18, 2016 02:34 PM
tyeo098
Nov 30, 2015 06:27 PM
CatmanFS
Sep 19, 2015 09:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
