Emmissions EGR question
Old May 10, 2002 | 12:55 PM
bigman's Avatar
OK, I've failed emmissions NOx was nearly double the limit. I don't have the paper with me, but it's something like 1560 versus a limit of 960. Now, I've replaced the air filter, I'm changing the plugs, wires, cap, & rotor. I've run a cup of water through my L03 engine. HOWEVER, I still need to address the EGR. I don't a get a check engine light, and frankly I've got other things I could spend $80 on. Question, does anyone think that just cleaning the thing would be enough, or should I just bite down and buy a new one? Anyone with experience with the Wells brand that Autozone sells versus NAPA versus GM? 157K miles.
Thanks,
Dan
Old May 10, 2002 | 03:49 PM
Vader's Avatar
An L03 is pretty straightforward. I'd remove and clean teh EGR valve, the corresponding passages in the intake, test the valve with a vacuum source, meter the solenoid, and test the system operation. Some time ago, someone posted a flow chart from a shop manunal for the EGR system diagnosis if you want to search the archives for it.
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
