Spark Plug Temp Range
Old May 10, 2002 | 09:16 PM
92BlackRS's Avatar
Ok, Maybe I am a retard , but how do know what the temp range is of spark plugs. I'm going to install a 160* stat and jet fan switch to run a little cooler. Do I need to worry about this or will stock plugs be OK??
Dazed and Confused
I don't remember forgetting anything
Old May 10, 2002 | 09:22 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
As far as I know they're all the same, except copper conducts better than platinum.
Though with a 160* you might get slightly less mpg than say a 180* since all the fuel might not get burnt.
If you're running a computer I wouldn't go with a 160*.
Old May 10, 2002 | 09:35 PM
92BlackRS's Avatar
So you think a 180* stat is best choice? I am running a computer.I have a 305 TBI and I like my gas mileage just like it is now. Also. I don't want any computer problems by forcing the car to run cooler than stock. Thanks for your help.:hail:
Old May 10, 2002 | 09:38 PM
Car: 99 Formula
Axle/Gears: 342
I don't know everything about CC cars, but I hear that a 160* might cause some problems. I would go with a 180*, and if you want to run cooler, maybe try some water wetter.
I'm not positive what a JET fan switch is, but I assume a lower temp that the fan turns on at. Which will help a lot, since stock setting is around 220*.
Old May 10, 2002 | 09:50 PM
92BlackRS's Avatar
Yeah, I 've heard horror stories about 160* stats and then people who had no probs at all. The Jet fan switch turns the fan on @200 and off @ 185* on the the one I'm getting. I've just noticed people on these posts make reference to a lower temp range spark plug and I had no clue what they where talking about. Thanks again.
Old May 11, 2002 | 12:16 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
i had a 180 it was great i put in a 160 car ran like **** , put back in 180 perfect.
Old May 11, 2002 | 01:02 AM
Chad Oliver's Avatar
Car: 67 ss 89 rs
Engine: 327 350tbi
Transmission: 5speed
The temp range of a spark plug is used for a hotter or cooler spark. If you drag race alot you'll want a cooler plug, try champions, If you don't want to change plugs every 3,000 miles or less check out bosch platinums. I don't think they print the temp. range on the boxes so you'll have to gamble with the parts store guy, preferably go to a performance store or call loper's.
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
