Installing Water Pump..HELP
Old May 10, 2002 | 10:14 PM
TransAm87's Avatar
Well i took out everything and i am going to install my new water pump tommarrow morning, is their any special method or easy way to do it..I am going to line everything up to make sure i put the bolts in the correct spot, i am going to use rvt on the 2 gaskets, I also got the march underrive pulleys that i am going to put on at the same time, and i got the 2 new belts,but any suggestions with the water pump or good tech or diagrams for my 87 T/A
thanks
aj
Old May 11, 2002 | 12:27 PM
Vader's Avatar
Suggestions?
Remove the rear cover of the replacement pump and inspect the impeller before you install the unit. I've seen a lot of remans with eroded impellers that barely move any coolant, but they're sold with a "lifetime" warranty anyway.
Clean the replacement pump of any rust inhibitor coating and paint the outside (except the gasket flanges and hub/shaft) to prevent rust. There is no real need for a high temperature enamel here since the pump should never exceed 300°F. Plain old Rustoleum should be fine.
Clean the gasket surfaces on the front of the engine thoroughtly and you won't need any RTV sealant, just a little High-Tack adhesive to hold the gaskets in place while you mount the pump.
Since the cooling system is already open, this is a great opportunity to flush the system and install a new thermostat. Your new pump will appreciate the lubricant and seal conditioner in the fresh antifreeze mixture.
Old May 11, 2002 | 01:24 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
instead of rtv or the sticky gasket adhesive at auto stores just use 3m adhesive. that stuff from autozone doesnt hold SH!IT on. plus the 3m will just melt/burn off from the heat so them it is only temporary. plus if that auto adhesive actually works for u is bonds the freakin gasket to the surface of the part and makes it even hard to scrape off the next time you change something.
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Jan 9, 2020 08:29 PM
toronto formula
Nov 10, 2015 06:17 AM
lakeffect2
Aug 23, 2015 08:44 AM
