What compression do I have? Part# inside
Old May 11, 2002 | 07:46 PM
DFIance's Avatar
I have a 350, .30 over with TRW Forged pistons, if I gave you these numbers would you be able to tell me?
Either with a 64cc or 72cc head.
On the top of the piston it shows in a bigger font L2256
littler font 99295 .30
Old May 12, 2002 | 08:56 AM
boogie's Avatar
If the decks are uncut on your block your CR should be real close to 8.6:1 with a 76cc chamber head and 9.7:1 with a 64cc.
Lonnie
Old May 12, 2002 | 09:04 AM
boogie's Avatar
That would be 8.9:1 with a 72cc.
Old May 12, 2002 | 09:51 AM
Vader's Avatar
According to my reference, TRW L-2256 pistons are flat top, forged, with four valve reliefs (totalling about 5cc), so with a nominal compressed head gasket thickness of 0.039" and a deck height of -0.015" under 76cc heads, you static would be 8.76:1. The same parameters with 64cc heads would increase the static compression to 9.90:1.
If you want to run the numbers youself, download this worksheet:
Engine Calculator.xls
Old May 12, 2002 | 11:32 AM
DFIance's Avatar
Well the block was decked last year and I am getting New Heads, does this change anything? Thanks for the replys.:hail:
Old May 12, 2002 | 01:40 PM
Vader's Avatar
Obviously, the deck height alteration will change the static compression. It's all in the calculator...
Old May 12, 2002 | 01:45 PM
DFIance's Avatar
Honeslty I have no clue about this stuff. Thats why Im askin.
Old May 13, 2002 | 08:09 AM
Vader's Avatar
That's quite alright. There are a lot of things about which I have no clue. If you download the spreadsheet, the calculations are built in so all you have to do is enter your specific engine dimensions and get the results.
Linson
Oct 24, 2025 02:00 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
KO1
16
Oct 15, 2015 05:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
