Car hesitates over 60 mph ?
Old May 12, 2002 | 10:00 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
I have an 89 Formula 350 with tpi and I am experiencing a hesitation when I try to accelerate more than 60 mph. If I accelerate from a stop the car pulls real hard until I get around 60 mph and then the engine starts to skip & sputter and then stops when I let off the gas. It will cruse along fine at this speed but as soon as I try to accelerate past 60 mph it starts to skip again and the needle on the tach bounces. Another thing that I noticed is when I have the windows down and when it starts to skip I can smell fumes from the engine like it is runing rich, so I think it is an ignition problem. The wires, coil, cap & rotor are all new. Other than that the car runs fine it is almost like the car is governed at 60 mph. Any ideas where to start checking? Thanks!
Old May 12, 2002 | 10:10 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Do you have a cat?
Old May 12, 2002 | 11:02 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Yes, the car has 2 and they are original.
Old May 13, 2002 | 08:06 AM
Car: 99 Formula
Axle/Gears: 342
I would run the car for awhile and at nite look under the car to see if they're glowing.
Old May 13, 2002 | 07:08 PM
JunkHead84's Avatar
check your fuel pressure, u might not be getting enough fuel at that speed.
Old May 13, 2002 | 07:35 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
That is a good idea, it is an intermittent problem and only happens once in awhile. Like I said it is speed related, I can sit at a light and rev it up and it runs fine or I can accelerate just fine until I reach 60 +- mph. Very strange!
BlueIroc-Z
Jun 9, 2019 03:22 AM
B_Dubya
Aug 26, 2015 05:09 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
