questions about water pump
Old May 13, 2002 | 12:51 AM
nesluopetan's Avatar
Ok, i feel like a retard asking this, but better to be safe tha sorry. I just took off my flex fan, and put on dual electric fans.
do I have to put any bolts back in the 4 holes that the flex fan bolted in? or do I just leave it with no bolts in the 4 holes? this should be a quick one for you guys. I just dont undertand how that pulley would stay on without the bolts in it, know what i mean?'
nate
Old May 13, 2002 | 01:13 AM
SkyWarrior's Avatar
Car: 1986 Pontiac Trans Am
Engine: 305 LG4
Transmission: Borg Warner 5 Speed
I don't know for sure, but I'd put them back in. The pulley will look better with the bolts in, rather than the empty holes.
Old May 13, 2002 | 06:42 AM
1986redbird's Avatar
YES, for sure put the bolts back in, they also hold the pulley on the pump as well as the fan. you may find the bolts are too long depending on how thick the fan flange was, if so, go to the bolt store and get some shorter ones.
Old May 13, 2002 | 01:58 PM
Chevy83Z28's Avatar
I agree with the last post, you'll need to get shorter bolts but you definitely need bolts to hold the pulley to the water pump otherwise you could easily send that pulley right through your brand new fans and radiator
(get the bolts!!!)
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
