Has anyone used the Gapless piston rings?
Old May 13, 2002 | 07:52 AM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Hi everyone,
My question is : has anyone ever used the gapless piston rings before & if so was it a big difference in vacumn & performance from the standard piston rings?
Old May 13, 2002 | 04:57 PM
tpi_roc's Avatar
gapless is somewhat of a gimmick
All rings have a gap
Old May 14, 2002 | 08:31 AM
Vader's Avatar
The "gapless" compression rings do a little better job of sealing the ends of the gaps due to the overlapped joint. I doubt that you would detect much of a difference in compression, leakage, or idle vacuum between the gaapless rings and a fresh set of file-fit rings.
However, as the engine wears the gapless rings should have a theoretical advantage. Then again, if you use syntheticc engine lubricants, the file-fit rings won't wear enough to leak either. But that's just my experience.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
