this setup capable of 13's???
Old May 13, 2002 | 08:01 PM
Don_89Iroc's Avatar
with the mod's in my profile......
exc. swaping in 1 3/4 SLP headers
268 comp cam, 218* duration and .485" lift
P/P L98 vette head's
ported intake, plennum, and runners w/ 52mm TB and 24lb/hr. inj's
3.42 or 3.45 gears w/ stock 9bolt housing
rebuilt 700R4 w/ vette servo and shift kit
aluminum driveshaft
Will this setup run 13's???
Thnaks -Don
P.S. forgot 1.5 roller rockers
Old May 13, 2002 | 08:23 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If it's a 350 it might be iffy, without headers the engine will choke.
Old May 13, 2002 | 08:58 PM
iroc22's Avatar
I think it might squeeze into the 13's. The L98 heads definitely being the weakspot.
Old May 13, 2002 | 11:00 PM
Fade07W's Avatar
Okay, just to see the difference between TPI and Carbs looking at my sig what is a hypothetical run for me? With the stock 2.73's and with the future 3.23's
Old May 14, 2002 | 09:02 AM
CobraKiller's Avatar
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
If you put the headers on you'll be in the 13's if it's a 350. A free flowing exhaust is what you're gonna need. Just remember if you can't S H I T you can't eat.
Old May 14, 2002 | 09:07 AM
Car: 99 Formula
Axle/Gears: 342
lol
Old May 14, 2002 | 09:35 AM
85transamtpi's Avatar
I HOPE that setup would at least pull a high 13. If a L98 car runs low 14's stock and you are changing the cam, porting the intake and changing heads, adding headers, and gear...I hope theres at least a half second.
Just be careful when running L98 vette heads. If you are talking about aluminum 58cc heads you might run into serious knock retard problems. You'll need custom programming.
-Doug
Old May 14, 2002 | 10:22 AM
Car: 99 Formula
Axle/Gears: 342
But he said he's adding all that EXCEPT headers.
Old May 14, 2002 | 11:10 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
if that setup doesnt get into the 13's there is something wrong.
I have a bone stock(yes bone stock, never lifted the vavle covers) L98 with chip(Stage 2 Fastchip),headers(cheap flowtechs) into SLP exhaust some suspension stuff and a little homemade cold air intake on DR's and ran a 13.89@99. He's talking about a cam,intake work and injectors, of course headers would be a HUGE upgrade along with that other stuff but there is no reason why he shouldn't hit the 13's
Old May 14, 2002 | 12:16 PM
hey fly89gta..just curious how much did the TTA conversion end up running you. I still have a 200-r4 lying around for when I was considering transplanting a 3.8 GN motor into the IROC. I'm still kinda tossing the idea around.
Old May 14, 2002 | 01:28 PM
Don_89Iroc's Avatar
sorry about the confusion but, i already have edelbrock TES headers, but i said i wanna swap them for SLP 1 3/4 header's, and dont forget the 1.5 RR in there i also will do some suspension upgrades before taking it to the track like sub-frame connectors and whatnot...........so should i run 13's???.........Mark A. S.????????:hail:
Old May 14, 2002 | 01:42 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
I say 13's
Old May 14, 2002 | 02:10 PM
Car: 99 Formula
Axle/Gears: 342
Easily.
Old May 14, 2002 | 02:59 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Cobra, i spend 2K on the motor for ALMOST everything, i just needed little things here and there(intake gasket, pcv valve, a few special bolts and stuff). With everything complete and in the car and running it was around $2500.
not bad considering i don't need anything else, rebuilt 2-3K miles ago...search www.turbobuick.com for engines, i've seen em go as cheap as 1800 bucks(86-87 intercooled motors, damn near complete) which is a hell of a deal.
As for the swap its not hard...not any harder than a V8 to V8 swap...that only thing you have to swap out is the motor mounts that bolt to the x-memeber(but the x-memeber already has the bolt holes on it
Old May 14, 2002 | 10:28 PM
I frequent turbobuick.com and try and pick up as much info as possible. Did you use a buick 3.8? or a Motor from a TTA? Cause I believe they have different heads. And did you just bolt it up to your 700r4? Any help is appreciated..thanks
Old May 15, 2002 | 08:35 AM
fly89gta's Avatar
Car: 2018 Camaro SS
its a true TTA motor from a wrecked TTA. I'm using the 700r4 for now with TCI's adapter plate, that is until i gather all the parts for a 2004r swap(torque arm,x-member, driveshaft, then a bullet proof 200)
like i said it was a pretty straight forward swap, i will say this though when u buy a motor make sure its complete, some parts are getting hard to find, especially the TTA specific stuff. As for you, do u want AC? if not i wouldn't bother swapping out the heads and pistons, too much trouble, if u want the AC well then i guess you're gonna have to
Old May 16, 2002 | 09:01 AM
Vader's Avatar
Stop paying all your attention to the front end of the driveline and start looking at the business end. You'll need decent traction to get a good hookup. New87 picked up several tenths with drag radials and some attention to the suspension, and that's on a 305 car.
Stiffen up the lower control arms and track bar, brace rod, and brackets. Adjustable or drag shocks might also help with traction at the rear axle.
Hook up well, and you should have the power for 13's. If you're doing about 80 when your halfway to the traps, you'll beat the 13 second clock.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
