Could too much blow-by ruin the EGR valve?
Old May 13, 2002 | 10:47 PM
KS91Z28's Avatar
I recently rebuilt my engine and made the mistake of checking everything very carefully except for the ring end gap. (I trusted O'Reilly's). They gave me the wrong size rings and I had a lot of blow-by. After tearing the engine back apart to put the correct rings in and putting it all back together, I finally have my car running good again. The only thing is, now the engine is really noisy. The sound is kinda hard to describe. While the engine is idling, it almost has that distinct sound that a diesel makes. When I try to narrow down where the sound is coming from, it seems to be the noisiest at the EGR valve. Any ideas?
Old May 14, 2002 | 12:40 PM
KS91Z28's Avatar
I just realized this morning that it sounds like that even while I'm driving. It sounds like I should be driving a Duallie down the road or something.
Old May 14, 2002 | 04:19 PM
KS91Z28's Avatar
I really need your help with this guys. Just let me know what else you need to know. I'll tell you anything you might need to know in order to help me out on this. Thanks in advance.
Old May 14, 2002 | 04:25 PM
RJR99SS's Avatar
well hmm...have you tried at full throttle? i'm not sure if egr is suppose to shutoff at wot on f-bodies, but i guess its worth a try. if the sound goes away at WOT then maybe that would help you out...
Old May 14, 2002 | 04:27 PM
KS91Z28's Avatar
I haven't tried that yet, but considering that I only have about 60 miles on the engine so far, I'm not really wanting to go WOT quite yet.
Old May 14, 2002 | 04:47 PM
RJR99SS's Avatar
huh?
unless you put it together wrong wot wont hurt anything.
Old May 14, 2002 | 04:54 PM
KS91Z28's Avatar
I was always taught to go easy on the engine during the initial break-in.
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
m00n420
Sep 11, 2015 02:39 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
