Stealth RAM Question
Old May 14, 2002 | 12:13 PM
Bluebird's Avatar
Car: 1991 Pontiac Firebird
Transmission: 700R
Ok.. I am looking into buying the ZZ4 Crate motor from
GM Performance parts, (Aproximately 3500.00) not including shipping..
Now.. Lets say I decide to go on the stealth ram setup (this was advice from fellow thirdgen.org pimps) hehe..
1. Anyone got a rough idea what that setup cost.
2. I assume it comes with it's own computer and wiring harness?
3. Will my gauge clusters work, or will I have no speedo, tach, and stuff after install, and a engine light on the whole time?
4. If # 3 is true.. what other suggestion would be better that would not cause problems with the existing instrument panel functions?
Thanks!
Mark
Old May 14, 2002 | 12:51 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
1. Well, since you have toliet bowl injection, a lot. In addition to the stealth ram, you're going to need injectors, computer, harness, fuel pump, etc.
2. the stealth ram is available as a compete unit for $2700, or just manifold/plenum & rails for $450.
3. Your gauges have very little to do with your motor.
4. see above.
9192camaro
16
Feb 3, 2019 12:21 AM
Mutillator
Sep 17, 2015 04:38 PM
mddaniel
Sep 8, 2015 05:16 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
L98GTA87
Aug 11, 2015 06:55 PM
